Can't close change tray - can't get whatevers blocking it
My change tray won't close all the way, I think theres some coins behind it that are blocking it, but my fingers are too big to get back there, and I can't see any way of pulling the tray out. Is there some easy way to get whatevers back there out? I have a 99 TL if it makes a difference.
the best way i know is to take the center counsil apart to do it. sorry. i had the same damn problem, now i just empty it out more often, like after the 10th time taking it apart
On the way!
I had the problem also. Get a flashlight and look in at the far inside corners of the tray. I had a penny lodged there and was able to get it out with a screw driver that I wrapped tape around to snag the penny.
It's a quick fix if you can see the coin and get the screwdriver to it.
BTW - mine's and 02 - I don't know if it's different.
most of what ive seen in mine was just behind it blocking it you can pull out and up a little bit and jiggle it around and it MIGHT shake them loose, if your lucky enough like fla-tls said try his method, other wise break out the philips screwdriver
o yea, that was mad annoying...wen it happened to me the coin was in pretty far to the point where i couldnt get it out. i jus told the dealer wen i went in to fix that seatbelt lite problem we all had a while back. they got it out no charge =D
