Can anyone tell me why this happens?
Every so often as of the past 2 weeks...when I start my car after it's been off for a few hours, sometimes I have to turn the key and hold it for an extra second or two before it starts. Before, I used to just turn the key and it started almost instantly. I just recently changed the oil and replaced it with synthetic and I have 80k miles on it...I had it inspected at about 75k and it was fine...I only ever use 91 octane and up...I drive very conservatively for the most part...anyone have a clue? Thanx!
I've noticed the same thing with my car. It used to always fire up right away and I would almost never hear the thing turn over because it was so quick to start. However, nowadays, sometimes it turns 5-10 times before starting, but it does it at random times (from a totally cold start to a re-start on a hot engine). Also, I just replaced my battery about 8 months ago with a new Diehard gold.
Could it be a faulty starter? I noticed this happen once or twice in the winter but I figured it was just cold. But in these past 2 weeks, it's happened 3 or 4 times. It still starts right away most of the time. I'm just wondering if this is the beginning of something....cuz it's always nicer to catch it early...
So you think everything is fine? Nothing I should worry about? Also, last time I changed the oil, I overfilled it a little....but not too much...it's down below the line now...would that have anything to do with it? Is something flooded?
Just a thought, but I know when the temperatures start to climb they change the mixture of gasoline. Something to help with smog. Might have a difference, don't know.
Also, do you use fuel injector cleaner regularly?
Originally Posted by seattle dale
sounds like what you would do to a diesel waiting for the glow plug to warm up. what is this all about? Don't get it?
