calipers
Just too cool
calipers
I seen caliper paint range from 15-40 dollars. One comes in a spray and they other you have to paint it on. Which one would work best? and do i have to remove the caliper to paint it?
$4 for high heat paint from Autozone. It is all the same sh!t.
No, you don't have to remove the caliper to paint it. The spray works good. Just cover all areas you don't want painted with newspaper and tape. Clean, sand, prime (x2 coats), paint (x4 coats) with clear coat being optional. I got some gloss high heat paint so I don't think I will need a clear coat.
Originally posted by rayman009
how much does primer cost?
so i first apply the paint and then sand it down, and then apply the primer?
You can also add a couple of coats of clear coat, thought that isn't really necessary.
I've done it before for my previous vehicle. It's takes time, but it's not that hard. But, I didn't prime the calipers though. My friend had them on his car, he said he just sanded it and painted it with cheap ass paint. The paint we used wasn't even high heat (high heat didn't come in yellow), it didn't peel off at all though!
Yes, take off the tire, but you can leave the caliper on if you want, but you will have to tape off everything you don't want paint on. Also, you will have to let it sit until it dries...should be on the instructions. I would recommend not painting them if they are hot...let them cool down.
so...i'm assuming i have to remove the tire right?
any good brand of paint i should use?
Also, once you are completely done, leave the paint to dry until the next day. I believe the paint I got requires a 12 hour dry period. It should tell you on the paint can. So, I will make sure I don't have to go anywhere after I finish painting my calipers.
Just too cool
i have some engine enamel, will that work with the calipers? because it says it can be put on most surfaces and with stand heat up to 500 degress F. Also i noticed that the rear caliphers have gaps between them, any tips on how to do those? After painting the calipers can i put the wheel back on? What is the point of sanding the caliper before painting it?
Wait until the calipers are not wet to the touch, then you can put the wheels back on.
Sanding the caliper smooths it out and helps make the surface even. It also removes any dirt or debris that didn't get removed when you cleaned it.
I am painting my valve covers and doing my mesh grill at the same time as my calipers that way I don't have to sit around waiting for my calipers to dry. Maybe you could do a couple projects at once so as not to get bored.
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
