Caliper ?
NorCal you Beezy!
Caliper ?
My baby's front right caliper came of yesterday while driving...
Does anyone know the name of the part that holds the caliper to the braket?
It has to be a screw or bolt of some sort... Any suggestions would be good
Yes I called Acura and they said they don't give out part #'s so I'm stuck.
F
F
that's pretty scary that your caliper came off when you were driving. the caliper is held on the brake bracket with two bolts.
http://www.acuraautomotiveparts.org/...prddisplay.jsp
it should be part #22 or 23. just print out that page and bring it to the dealer.
NorCal you Beezy!
Heard grinding noise coming from front end pulled over and seen my caliper mis-aligned from rotor... I pushed it back into place. Noticed a slight pull to the right. Parked in my garage... Expecting the pin to come in today. Shet I might just upgrade my brakes but still deciding.
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
