A/C Low line pressure
Old Jun 3, 2007 | 03:59 PM
KazeSupra's Avatar
Supra Freak...
I did a search through all of the A/C threads I could find, but couldn'f find my answer. With the car off, how much pressure should I be seeing in the low pressure line of my A/C system? Any help would be great. Thank you.
Chris
Old Jun 3, 2007 | 09:30 PM
01tl4tl's Avatar
The AC pressure is checked with engine running and system on
Old Jun 12, 2007 | 07:42 AM
KazeSupra's Avatar
Supra Freak...
OK, so do you know how much pressure I should see on the low side with the car and system on?
Old Jun 12, 2007 | 09:13 AM
fsttyms1's Avatar
From a thread about half way down the 1st page
https://acurazine.com/forums/showpos...9&postcount=19
Old Jun 12, 2007 | 09:35 AM
LEX588's Avatar
LOW pressure should be anywhere from 20-45 PSI (this is with the car ON and A/C on full blast)
HIGH pressure should be in the 150-200 PSI interval but can be slightly lower or higher(car OFF)
Pressure readings depend on temperature and humidity, so keep that in consideration also.
My A/C system was properly refilled the other day so when I get home I'll take the exact pressure readings and post them here
Old Jun 12, 2007 | 10:23 AM
KazeSupra's Avatar
Supra Freak...
well, I just checked mine properly, and it was 0. Guess I got some seals to replace and then a recharge. Thank you guys!
Old Jun 12, 2007 | 10:28 AM
01tl4tl's Avatar
0 psi indicates a serious leak has occuered
- not, lets throw some seals on it and all is well
First you need to add some dye and find the leak, replace o-rings, or bad line or even the ecompressor and receiver dryer! All depends on how long the sytem was out of commission
01CLOwner
Oct 9, 2015 01:07 PM
Sep 21, 2015 08:44 AM
Sep 17, 2015 08:57 PM
Sep 17, 2015 10:16 AM
HeloDown
Sep 8, 2015 06:51 PM
