A/C Air conditioning recharge
Is it possible to damage the A/C system with overcharging, or even undercharging?Can I top off my A/C unit with one can of refrigerant, or should I take it into a local garage?
As hot and muggy as it has been in Philly (and probably a good part of the rest of the country), my A/C doesn't seem to cool down the car, even with the fan cranked to the maximum and the temperature set at its lowest 60F. Today, with temperatures in the mid-80s, it wasn't that bad. Is this experience typical for anyone else?
I have a 2000 TL with 57,000 miles. Should I just bring the car in for its 60K maintenance and have the dealer take a look at my A/C system?
Sorry if I posted this in the wrong forum.
is there something wrong with your ac now? if you overcharge it, it wont work properly. if you undercharge it, it wont be as cold as it could be. i suggest you take it to someone if you dont know what your doing but if you do decide to charge it make sure you know which line is the low pressure.
I suggest you not try to charge it without a good set of gauges. Its very easy to overcharge the system in the TL. I just did this, and my AC stopped working altogether. I had to take some out before the compressor would kick on again.
Originally Posted by Da_iLLeZt_TL973
im experiencing this problem to....cant you just put refrigerant to solve the problem?
Originally Posted by bkzjimmy
but doesnt the heat use the same filters??
SidhuSaaB
05-30-2020 12:40 AM
lanechanger
10-13-2015 10:56 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
2002, ac, acura, air, cl, condition, conditioner, conditioning, mdx, overcharge, overcharged, recharge, recharger, refill, tl, tsx
