Burnt out HID?
Old 12-27-2003, 11:55 PM
Aydin's Avatar
Burnt out HID?
Does anyone know how to tell the difference between if your HID system is done or if its just the light?
I am thinking its the system, cause when i first turn my head lights on they both come on fine and aftere a few seconds, my driver side one dims out and turns this doll colour. Is this gonna be a expensive repair????
Old 12-28-2003, 02:03 PM
corey415's Avatar
Re: Burnt out HID?
I think you need to replace your bulb. A new d2r bulb is under 100 bucks i think.
Old 12-28-2003, 02:11 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
could be either your bulb or a balast going. im gonna guess on the balast. i dont think if it were a bulb that it would even come on if it was bad
Old 12-28-2003, 07:10 PM
Aydin's Avatar
ya i don't know if it is the bulb. Cause it turns on and then dims out. Any body else experience this?
Old 12-28-2003, 07:57 PM
Aydin's Avatar
this is a pretty bad pic, but you could sorta tell the driver side one is dimmer. It looks a lot worse live.
Old 12-29-2003, 12:03 AM
Type II Coupe
AznBalla's Avatar
Same problem here! I'm gettin it fixed sometime this week.. My car was involved in a frontal collision and the driver headlight assembly was smashed so they replaced it. Once I let them know about the dim side, they said bring it in and they'll fix it, it wa something to do w/ wiring... Not the bulb...
Old 12-29-2003, 12:09 AM
Comptech Freak
samkws's Avatar
100?
i thougth it's 200...
Old 12-29-2003, 12:30 AM
Aydin's Avatar
Hey, AznBalla can you let me know what it is exactly. Also I have not been in a accident or anything, you think it can just get loose. I am thinking the HID system is not having enough power to keep the light lit.
Old 12-29-2003, 07:33 AM
jpadilla's Avatar
did u clear out your headlights(can't really tell)? may that have caused the problem?
Old 12-29-2003, 11:30 AM
Aydin's Avatar
Going to Acura today. They say its probably the light. I will let you guys know. I called one Acura and they said it could be the bulb, but its non refundable. I am going to a second one i called and they said they would try out a light and if its not it, they will do further research. Good guys.
Old 12-29-2003, 12:10 PM
nyctl's Avatar
when i got my light replaced from a front collision. the new bulb was not as bright as the old one.
apparently they didn't install a new ignitor/ballast and when the new part came in, there was no more difference.
The service mgr said that if that part was not changed the same time as the bulb, then the bulb would probably end up burning out.
Old 12-29-2003, 02:25 PM
booooo
TL_Diplomat's Avatar
i have a d2r OEM acura BuLB for sale 75$ shipped
Old 12-29-2003, 03:02 PM
randomwalk101's Avatar
you have two bulbs...take the left and put it in the right...if it dims out then it's the ballast...doesn't take a damn genius to figure some stupid **** like that out...come on peeps!!!
Old 12-29-2003, 05:45 PM
Aydin's Avatar
haha.
"you have two bulbs...take the left and put it in the right...if it dims out then it's the ballast...doesn't take a damn genius to figure some stupid **** like that out...come on peeps!!!"
I would have done this, but didn't wanna mess around with it. I have no idea how the HID system works and if its just like regular lights. I did do this at the Acura dealership though. They're awesome at the N. Shore one if anyone is from vancouver. They changed the light for me for 188 taxes in and no charge for labour. The old one is bluer but i think thats normal. WEll see how it turns out. I got 1 year warranty.
MilanoRedDashR
10-08-2015 10:30 AM
mshipon
2G CL Problems & Fixes
09-28-2015 12:14 PM
MilanoRedDashR
09-27-2015 10:15 PM
h22lude
09-27-2015 06:22 PM
Quick Reply: Burnt out HID?
