Broken windshield washer rubber hose
1 Attachment(s)
Hello,
I saw that this is the oem part number for Acura TL, year 2000 rubber hose. 95003-07008-70M BULK HOSE, VINYL (4X7X8000)OEM CUT SIZE: (4X7X700) Also, where can you buy after market replacements. This would be to connect two pieces of hose together. for example: 76828-SH0-A02 JOINT L, WASHER TUBE (DENSO) Would this be an acceptable equivalent. Prestone/5/32 in. x 6 ft. windshield washer hose vacuum tubingPrice:$3.99 Part Number: WV0532 Alternate Part Number: 65115 Thank you. |
If the ID (for the connectors) and the OD is the same (for clips) no reason it shouldn't be fine
Yep, as long as its the same id then it will work. I had to replace a section of mine and thats all i did. I went to the parts store and got some.
Those 5" vinyl hose pieces are like 10 bucks each. Silly expensive.
Hello,
Does anyone know about how to route new windshield wiper hose to the pump motor assembly. How is this done. Is there a diagram. Thanks. |
