Broken sway bar end link
Has any one here had a sway bar end link break? Using Comptech sway bars for about 6 monthes. Car was handling poor, and there was some clunking on bumpy corners. Found one of the end links on the front sway bar was broken.
Randy
Randy
These usually aren't very hard to replace. It's reallty just a long bolt, a nut, 4 washers and a spacer.
If you've ever rebuilt a skateboard (without Gull Wing trucks anyway) then it'll be second nature to the order they get assembled.
I have all ready replaced it.
The end link on the TL is more like a steering tie rod end. Except that the socket the ball swivels in is plastic. This plastic piece broke out of its housing.
I was wondering if any one else has had this problem.
Randy
Randy
^so what hit ya or what did ya hit?
yup that would do it!
I might be wrong but when I bought bigger sway bars I of course started cornering harder and faster...and eventually broke the left rear link. This is the one loaded when making those hard right sweepers getting on freeways, you know, the on-ramps. Once replaced it hasn't done it again, but I also have not pushed it to the limits like I used to for the fun of it.
3rd Gear
I'm suffering from a broken sway bar link. Do you know where I can find a replacement? Are there after market applications that will have a little more strenght in order to avoid this problem once I buy and install aftermarket bars?
Thanks for your help!!
Ynitro
Ynitro
most times out of 10 the oem ones are strong enough.
6G TLX-S
Originally Posted by edgalang
Concrete divider during a banked turn after a 180 degree spin-out.
Purchased: April 28, 2001
Go for a complete wheel alignment too. Sometimes suspension components may also be bent out of spec. from the impact.
Thank you sir....however my post was 2 year ago.
I was being sarcastic. If only my link was still available, you'll see that my car was half way to being totalled.
Dragging knees in
Ynitro
Ynitro
No aftermarket alternatives at this point. Good luck.
3rd Gear
Originally Posted by Pure Adrenaline
Send an E-mail to hondacura world@aol.com. His name's Tim; tell him Rob from Michigan sent ya. He'll take care of you; he has excellent prices on OEM parts.
6G TLX-S
Ynitro, standard aftermarket sway bars will always increase oversteer.
Dragging knees in
Just sharing a little story --
My friend's heavily modded Integra Type-R has 27mm front sway bar and 26mm rear sway bar. His car has power-on oversteer (let's not even get started on throttle-lift oversteer). If someone who didn't know much about cars went for a ride in it, he would swear that it was a RWD. It sends a shiver down my spine every time he dives into a corner really hard and exits with the ass end coming around.
marcelft
07-10-2018 06:17 PM
MonkeyTrucker
09-21-2015 06:15 PM
k6biv
09-10-2015 06:37 PM
