Brake Light on Cluster
hello all
recently after starting up the car in the COLD, the brake light would stay on. not the "brake lamp" but the brake light, but after driving and a couple of pumps it would come off.
today after leaving work, started and it was on, but after 2-3 min of the car warming up and pressing the pedal at times to brake, the light went away, but came back on after a few more pumps....is that the brake switch acting up?
some things i notice is that whenever the car is in a warm area or been warmed up, like my garage or after going in a store, it doesn’t come on, only after being still for a good few hours....
anyone got an idea?
anyone got an idea?
MechEng
same thing happened to me a few weeks ago when it was about 15 or 20 degrees out. i figured it had to do with the cold temp since cold messes with the steering wheel controls and radio knobs too so i didnt worry about it. the temp has been above freezing since and it hasnt happened.
IMO dont worry about it. TL electrics suck in cold weather.
the float for the fluid level in the master cyl cap gets grungy when you dont change the fluid often enough (every year)
That can cause it to stick or other factors cause the seal in the cylinder to fail
New cap $35,
complete master cyl with res and new cap $80-100
If when you pump the brakes, the 2nd pump is firmer- you may have master cyl failure
Or if pedal sinks while holding at a stop- master cyl failure
DO NOT drive around with a master warning light on- its there to advise you of DANGER
New cap $35,
the LAMP light on means bulb-
the BRAKE light ON means system issue
MurdaZ: Hey I have the same problem, we cleaned everything out and it's still the same... We figured the sensor's movement is limited when its freezing cold... This is why it's ok when the car is warmed up... One of my boys that works at Formula Honda said the exact same thing... "I wouldn't worry to much bro"...
mada51589
05-03-2022 08:54 PM
brandnewcolony
09-12-2015 10:39 AM
