Body Kit Question?????? Help
I just recieve my body kit and can someone give me a DIY info.
and i wanted to confirm this the only thing you need to take out is the side skirts right? the front and the back you just add the extensions on??? any pix DIY would help Thnx
http://www.acurainspired.com/forums/...p?showforum=16
Sides you need to replace the stock one, front and back are add ons.
download the side and rear instruction. For the front just line it up and you need to drill two holes I believe. You'll see where when you line it up.
Dragging knees in
For the front, slip it on, line it up and drill holes. It would be better if you had someone to hold it on there tight for you. There are two holes on each side of the piece, by the wheel well. Drill holes there, and put screws in. Done.
For the rear, Slip it on, use the clips. It's kind of hard to figure it out first, but mess around with a little bit and you'll figure it out. And after installation, you will have gaps by the corners between the body kit piece and the bumper. Don't worry. Every kit has that problem.
For the sides, unscrew 4 per side skirt (I think... crawl underneath... it's easy to locate the screws) from the bottom. Now you're ready to take it off. It takes A LOT of force. Don't worry, you won't break them. This is how I did it and I think it's the easiest way. Let's take the passenger side for example. Face the rear of the car, put your feet up against the rear tire. Grab on to the side skirt and pull it forward. You'll hear a loud pop and it'll move like 3 inches forward. Take it off, get all the white things out, and put it on the body kit piece. You have to reuse them. Same thing on the other side.
Good luck.
Good luck.
Zonian22
11-14-2015 01:20 PM
09-04-2015 08:03 AM
Zonian22
09-02-2015 08:19 AM
