bigger rotors
Old 06-13-2004, 02:52 PM
UB6IB9
1st timer's Avatar
bigger rotors
When you change your rotors do you have to change the calipers also?
Old 06-13-2004, 03:25 PM
Retired MOD
Bitium's Avatar
no if you change the rotors with same dimension rotors.
Old 06-13-2004, 04:54 PM
Incubus's Avatar
I'm sure that larger rotors mean at least modified calipers.
Old 06-13-2004, 05:07 PM
'99 Acura 3.2TL
@cUr@-TL's Avatar
i dont think they make bigger rotors for the TL except the Brembo/Rotora Big Brake Kits.. they will cost you big $$$$ tho..
but going with larger rotors will definitly require some kind of modification to the caliper..
@cUr@-TL
Old 06-13-2004, 09:08 PM
UB6IB9
1st timer's Avatar
What rotors should i go with?
Old 06-13-2004, 11:08 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
no modification to the caliper it self just a bracket to move it out further.
as for what rotors you should go with? what do you want? a big brake kit or just a replacement rotor? the big brake kit will require a larger than stock wheel. if just a replacement factory size, irotors or rotora are great rotors. and for pads i wouldnt use any thing other than EBC Green Stuff pads
baelim
05-10-2018 09:53 AM
Ratheruneeq
09-28-2015 07:41 AM
Quick Reply: bigger rotors
