because teasers are fun.
#42
Originally Posted by vzuptnguyen
imagine this. a plexiglass/fiberglass piece cut to the shape of your corner airdams. you install whatever fogs you like but take the glass cover off the fog lights and replace it with that shape you cut out earlier. basically something like how the 02-03 foglights are. the light is dispersed out and appears larger, unlike a centralized oval or circle.
like these shaped lens over whatever fog you have.
Hummmm thats a great idea. You could cut and trim plexi to the shape of the corner pockets. Then pull the cover off what ever fogs (like the ones pictured) and reattach the piece trimed to fit the opening to the fog. The only thin is you would have to fid ones that you can still adjust angle and pitch (looks like the ones pictured you can.
Then you could just black out with paint around the area that has no fog.
#43
woooo!!
a bit late... but,
here's the DIY! post there for comments & questions pls:
https://acurazine.com/forums/showthread.php?t=152895
