Bad Oil Leak
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
What's up everybody, just turned 132,000 on my 2001 TL. The threads on the inside of the oil pan are stripped, so I've been using a dorman one time use 1/2 inch drain plug that tightens down. Every time I change the oil I put a new plug on. I've never had an issue of seeing oil on the ground, maybe just a drop or two, but lately I've been noticing a decent amount of oil under my car after it's been parked overnight or sitting for a few hours.
The oil was just recently changed and there's no leaks coming from the filter, so it's definitely coming from that drain plug. I really want to get a new oil pan put on by the dealer so I can stop worrying about having to top the car off or the plug blowing out while I'm driving, but it's probably going to be about $500 to do so.
Does anybody have any suggestions for what I can do to correct this? Any help is very much appreciated
I had this happen a couple years ago, I think my guy redrilled the pan and put in a larger plug. No problems since. Make sure you tell whoever does your oil changes about this if you have it done. A different size crush washer is required to prevent drip or leaking.
Make a note of what size/type washer for future ref.
Good luck....
Mike
Good luck....
Mike
Don't replace the oilpan, it could be a bigger job than you think. Just get the bigger size bolt from napa and it should fix the problem. Here it is:
https://acurazine.com/forums/showthr...trip+oil+drain
3.2TLc (06-12-2013)
IIDXholic
10-08-2015 07:53 AM
winkyyy
09-11-2015 04:40 PM
