back seat cushion
Old 11-10-2003 | 01:00 AM
nummicars's Avatar
8th Gear
back seat cushion
i am having this freakin problem of remove the back seat cushion. i'd aready loosened up the side of the cushion. but then the centered, back end...slightly off to the right...is stuck!! not sure what is holding it. anyone experience this problem?
Old 11-10-2003 | 02:36 AM
Pure Adrenaline's Avatar
Dragging knees in
The bottom cushion or the seatback cushion?
Bottom --
Remove one bolt, about 6 inches to the right of the center of the cushion. Then lift it up. Very simple.
Back -- You have to remove 3 bolts. You can see them easily once the bottom cushion is removed. After you get those 3 bolts out, lift it up all the way, until the metal brackets are out (the ones that the 3 bolts are holding in), pull forward, and it'll come out.
You have to fumble around a little bit with the seatback. I've taken it out like 5 times, and it still gets me sometimes. But besides the 3 bolts, there's nothing else hold it in. Just gotta push up and pull forward.
Old 11-10-2003 | 02:59 PM
nummicars's Avatar
8th Gear
i knew there was somehow a bolt there to secure the back end of the cushion (seat part). but then the problem is there is not enough space to access it with a tool or some sort....
Old 11-13-2003 | 08:30 AM
nummicars's Avatar
8th Gear
Thanks for the info on that one bolt near the back center of the bottom cushion Pure Adrenaline. I got it out and completed the project of installing comptech springs. Thanx again.
Old 11-13-2003 | 01:16 PM
joseph_99tl's Avatar
nummicars.
how do you like the ride?..
with the springs
Old 11-14-2003 | 12:56 PM
nummicars's Avatar
8th Gear
the ride is awesome!! the absorbing of the bumps and potholes of the street is a little, slightly harsher compared to the factory springs. other than that...it rides like as if there's the factory springs in there. very smooooth.
rockyboy
08-04-2024 10:35 AM
02-25-2020 09:57 AM
o8 ENVII 8o
11-30-2015 04:23 PM
d.lim
09-15-2015 08:54 PM
iRaw
ILX
09-05-2015 12:10 AM
Quick Reply: back seat cushion
