AV6/Odyssey Swap Performance Thread Of Record
Old 03-11-2016, 04:39 PM
  #41
CP13's Avatar
great to see some updated info... keep it coming...
Old 07-03-2016, 10:11 PM
  #42
8th Gear
Mac01CL's Avatar
Great read guys. I'm getting in Tuesday to start my av6 swap on my 01 CL
Old 07-04-2016, 03:50 PM
  #43
SuperGreg's Avatar
I'm just gonna chime in with my info although I just did it last weekend. IMO most of this info is interesting in that the swap appears to work, however my old tranny lasted 150k miles so I wouldn't consider even 10k on an AV6 to be indicative of a any huge improvement in reliability. We can only hope.
That said, 2002 TL Type S. 206k miles when my 2nd tranny failed (post 2005, blue bolts RMK reman). Replaced with 2007 Accord tranny, with just shy of 50k miles on it.
I have about 300 miles on it so far. It's almost perfect except for a small delay in engaging 2nd gear under full throttle. Not sure if this is normal, all other gears seem to shift immediately. I may try to adjust the solenoids some time.
Old 07-04-2016, 03:52 PM
  #44
SuperGreg's Avatar
Originally Posted by MBP 03
You don't have to pull the axles to get the trans out, but since the only extra step at that point is to remove the axle nuts, I prefer to just get them out of the way to have more room.
Yeah it's literally like 5 extra minutes of work to remove the axles and everything is way easier with them out of the way.
Old 07-08-2016, 08:14 PM
  #45
SuperGreg's Avatar
FYI after a bit of driving the 2nd gear shifting has smoothed out and appears to engage normally.
Old 09-21-2016, 02:57 PM
  #46
SuperGreg's Avatar
So, now have 210K on the TL, about 4K miles on the new tranny. I was actually not totally satisfied with the 1-2 shift as it seemed too soft, especially under full throttle and when the car was cold. I used the Sonnax solenoid adjustment tool (Solenoid Adjustment Tool - 88950-T - Sonnax) to increase pressure on solenoid B (which affects 1-2 upshift, 3-4 upshift). It seems a lot better, although there is a slight jerk when cruising at a moderate speed, then flooring it enough to downshift all the way to 2nd. But I'll deal with that.
Here is some video of the shifts now. Wish I had taken some before to compare. https://goo.gl/photos/mHuX9zEG9evhfD5f7.
dirtyspitshine
01-03-2023 08:23 PM
02-25-2020 09:57 AM
Zonian22
11-14-2015 01:20 PM
mugen_kid
11-13-2015 10:38 PM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
Quick Reply: AV6/Odyssey Swap Performance Thread Of Record
