Automatic Transmission Question
Is it possible to shift from neutral to reverse, while your car is moving forward ~30mph?
Are there any mechanism to prevent that from happening?
What kind of damages to transmission?
thanks
chiggartl
thanks
chiggartl
Yes, you can't move the stick into reverse from neutral when you're doing more than 5 or 10mph or so. Next time you're driving, put it in Neutral when you're slowing down. Turn off everything you can to make it as quiet as possible. Once you slow down past 10mph or so, you'll hear a click, that's the lock releasing so you can shift into Reverse. You can put the stick in Neutral and keep trying to push it to the right (not into reverse but in that general direction according to the shift gate. You have to move the stick to the right and then up to go from N to R...just move it to the right but not up.) and you'll notice when the lock is there and when you slow down enough, you'll notice the lock releasing.
while we're on that topic, can someone tell me if its bad to shift into neutral when comming to a stop? say im going like 40 and am comming to a stop sign, can i just throw it in neutral? i hear its bad to shift to neutral while moving.
Mike Bertram
09-10-2015 09:27 AM
HeloDown
09-08-2015 06:51 PM
