Attn: Songoku
Attn: Songoku
Since you used the Accord harness for your foglights, did you do the trick to run them with your parking lights?? If so, which wires do you tap into??
Or anybody else that has the answer please post, I think the first gen tl's are like the accords. You have two wires that you have to plug into the back of the light switch at the steering column.
Thanks in advance.
Thanks in advance.
Tried that one already, you will get a buzzing noise from the relay on the driver's side. It will let you run your high beams with the fogs on, but every time you turn on your parking lights alone you'll get that buzzing sound. I thought there could be another way but maybe not.
Thanks.
Thanks.
BlingBling INSPIRE 32V
Thanks.
Thanks.
What kind of car do you have??? Is it 1st gen TL???
