ATTENTION StreetEffectz
i see that install screens into the visor, and i was impress with the 6.4" version. what i wanted to know was: i've seen alot of problems with weight when doing it in the visor, because its kind of heavy holding it up. are you using velcro or anything to keep it up? your help would great be appreciated. by the way, what kind of screend do you usually go with?
'01 Lexus IS300
'91 Acura NSX
'95 Nissan Maxima
'01 Lexus IS300
'91 Acura NSX
'95 Nissan Maxima
I hope he doesn't mind me answering this, but the 6.4" monitors he most often uses are not heavy at all. I've seen him install monitors in a lot of visors and I don't know of anyone that has had a problem with them falling. The visors stay up on their own, but if you're concerned about them falling, I'm sure he'll have some suggestions for you. I personally would avoid velcro only because I wouldn't want to see it stuck beneath the monitor...might take away from that "clean" look...just my 2 cents though.
Those stealth look installs I have been doing in the headrests and visors are done with Santeca monitors. Weight in the visor is not an issue what-so-ever. And IF it ever was, which probably never will be due to the lightness of the monitor, velcro IS NOT an option for me. It would just involved putting a tighter restraint inside the rotating mechanism on the arm. No big deal! Thanks Dave!
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
