Anything else I need to take care of...
I have a 2000 TL that has 158,000 on it and just recently have taken care of a number of maintenance items:
-timing belt, a/c belt, power steering belt and tensioners
-power steering pump had to be taken apart and cleaned
-new anti-freeze
-transmission drain and fill x2 10,000 and 15,000 miles ago
-valves adjusted
-egr cleaned and Thermoblok spacer kit installed
-UR Pulley installed
-removed intake and exhaust resonator
-missing anything else I should do?
Is there anything else that is relatively inexpensive that I can do to up the performance of the car? And since getting the car back my right headlight ballast has/is dying, can I replace it with this one: http://www.carhidkits.com/hid-ballas...llast-190.html ? Thanks for anyones input!
-new anti-freeze
-valves adjusted
Yea I have NGK Iridium spark plugs and sea foamed before I put those in. As far as the bulb goes, the light will come on for a few minutes then die, it will come on again if I turn the lights off and on again. I tried unplugging the ignitor and plugging it back in, no go. The only thing that worked on the light was to unplug the ballast and plug it back in. I just don't wanna spend 160+ for an OEM ballast when a 100 dollar one can work...
Flyin' and Drivin'
Yeah I would stick to the stock stuff. I cleared my headlights a few years ago, and I did it because one headlight was already getting water in it. But I guess I just made the whole thing worse, bad enough that the water ended up frying the ballast. I ended up getting two new headlight housings, and complete new HID systems. It was all around 500 bucks, and I bought everything online and had my local dealer put it together for me.
Now the car is fixed up nice- invest in a few days of High Performance driving school- aka Track Days at your local racetrack
About $250 for a full day with Pro Race driver riding shotgun in your car- giving instant feedback on braking turning and throttle control
Awesome fun-
several threads on azine from members who have gone and came back saying- How did I survive all these years?,,and driving 30 solid minutes full throttle turning and braking is a workout! This car is amazing fun!!
Awesome fun-
A K&N air filter will help the removed intake resonator to work much better than paper filter
Seafoam needs to be repeated after a month/1 to 2000 miles for max results- then good for a year/15
08_UA7_Gr33k
02-11-2016 02:17 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
