Anyone else notice this?
If you have an '02 TL-S with navi, try this:
Start the car, set the climate control to auto and dial in a comfortable temperature. Let the system cool the car to the point where the blower has switched to its lowest setting and the recirc light is off. Then shut off the car (key all the way back) but *leave* the key in the ignition.
Does your climate control stay lit and still appear to function even though the rest of the car is off? Mine does. Until I remove the key from the ignition--then it shuts off. Is that supposed to happen? If so, what's the point?
P.S. This may work without navi, but I don't have access to a non-navi to test.
Originally posted by nickchop
Yeah mine does that. Here's a question: how do you keep the recirc on while auto is on? Recirc will work sometimes and sometimes not when I press auto.
- Recirculation
- Active vents (face, face/feet, windshield, etc.)
- Fan speed
- A/C on/off
- Heater regulation
So if you press "Auto" then override the Recirculation, the computer will still control everything else.
I often do this very thing myself... each time I pass some stinky or smoky areas, I hit the Recirc button.
Guest
Posts: n/a
Originally posted by JusMan
Adding to that: How do I keep my A/C off when I only want vent air. It's gets old by hitting A/C button and then the A/C off.
I may not be describing this right, but you go into the A/C control area of the navi and turn off the A/C. Then choose your fan level, and you've got fan without A/C. Works great, and its something I always wished I could do on my Legends, but never could.
Originally posted by lonny
Doesn't this car have a "retained power" feature that leaves power on even after turning off the key (as long as the door is not opened)?
I'll tell you what is annoying, but I've learned my lesson...You're inside the house and unlock the car door to go grab something out of it and by the time you get there, it automatically locks.
My TLS does not do that, or at least I've never seen it do that.
I don't know why our cars have headlights that stay operational when you turn off your car (for 15 seconds at least), but have power windows that die when you open a door. It makes no sense! I would like to be able to operate my windows even after my car is off, like I could with a manual window.
nickchop: After unlocking the doors with the remote, they will lock automatically after 30 seconds if you don't open a door. This is a safety feature to prevent people from inadventently unlocking a door after parking.
I tend to walk pretty close to the car before I unlock the door now, so it's not a problem.
1 Post
The older cars power windows would work even with the car off. This was a hazard as kids could get fingers or themselfs caught in the heavy windows of them days.
Then the automakers fixed it so that the key had to be in the ON position for the windows to work. I think automakers put the retain feature in some models as a convenience feature.
1 Post
Originally posted by pianoman41
I always thought the windows were disabled when the power was off in older cars because of the drain the motors put on the battery. Even now, with the newer, lighter and more efficient window motors, closing more than one window at once and holding them after they've closed (putting motor under full load) can momentarily dim the lights. In 70s and 80s cars, the motors required more juice and the batteries were less able to spare it. So automakers wanted to make sure you didn't wear out the battery opening and closing the windows with the car off.
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
