Any info or dyi for 99 tl p to type s swap?
For now your better off find wreck 6speed CL since Richie harness is very hard to get. There was one for sale in BM for under 3K in Maryland. (few months ago )
If you can find Richie harness here what you have to do since your 99 ( Like me )
With the 99 TL you will also need to get the 02-03 Type-s wiring harness an combing then two together to make 1. B/c the speed an temperature sensor are very different
GOOD LUCK
GOOD LUCK
im def doin the swap...i hope to have the swap together and in the car by at least april ...this should be a fun build as i do things different from anyone on here has done
...just wanna know if i can use the auto engine harness or not ? ive seen richie sayin you can use qand accord i4 clutch pedal...does i 4 mean inline 4?
Yes, you use the auto harness with the module.
And yes, you can use the clutch pedal that comes from the 4cyl accord. Remember you have to change your brake pedal as well.
LECKEY73
02-22-2016 01:32 PM
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
