Alignment shops on Queens
Styl1n
Hey guys how’s it going…..welll sittinlow and I are looking for a good shop in the queens area that will do alignment on lowered cars. My car will not go on any lifts around my area. I tried many and have been turned down for being to low to get up on the lift.
thanks
thanks
TYPE-S CBP MT
try this spot..
when i had my teggy sittin low thats where i went and they hooked me up... i got up on the lift, they adjusted my cabmer kit and did everything. give them a call and c what they say.
Whiteys Tire Service
(718) 277-3000
3395 Atlantic Ave, Brooklyn, NY 11208
(718) 277-3000
The Talk of New York
try Sears Auto Center, right across the street from Queens Center Mall. I went there last summer to do my alignment and had no problems, but then again, I can't really remember if I was dropped back then or not...
Styl1n
yeah I know whiteys on Atlantic, question right now i rub in the front when i go over big bumps or do really hard cornering, will there be any issue with rubbing more if i get the camber kits for the front and rear?
if you rub already with your current spring setup, getting a camber kit wont fix that. It will only address uneven tread wear on your tires. Ride height is dictated by your springs.
Styl1n
i got to change my inner and outer tie rods first then do the alignment...i have a 1 finger to no finger all the way around...do you guys still think i will need the camber kit...i am putting on my sway next weekend..
emailnatec
29
09-28-2018 04:27 PM
DerrickW
11-15-2015 05:52 PM
