alignment questions
alignment questions
just got the car aligned and the shop said the front wheel was ok, the rear wheels however is still a little bit off by almost a degree. the guy said there is a part that can be ordered and this will adjust the rear and make it close to the spec. did anyone else get this and what is the result of people who got an alignment after lowering thier car with h&r sport springs (1.75")
Yes...everyone will get negative "CAMBER" when they lower their car. It is around .7 degrees which is not very much at all. Some members will tell you a little negative camber is good *helps you around cornering* They sell camber kits with will fix the camber, but your tires are perfectly straight and parallel, so it isn't a problem. Most of the other members and I who drop their cars don't buy the camber kits. I think they run about $150 per wheel, so you would need 2, $300 for fix the camber which is not really neccesary
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
