air recirculation flap and control motor
need help with HVAC. can anybody post a pic or explain how the air recirculation button works? I'm getting fresh air from outside while the recirculation mode is on - orange illumination.
my A/C still works, just annoying because i'm smelling exhausts from older cars stopped in front of me. Is there a way to test the A/C by making it flash a code, i.e. blower motor, air mix control motor, mode control motor, evap temp sensor. where do i start checking?
i had that problem, it started when they replaced the panel and didn't hook up that button.
i'm pissed that it still draws in fresh air (but a lesser amount) when i press recirculate. i'm told that's a normal function, which i think is bull****.
when you close the vent, it should be CLOSED, not partially.
you can push the button and the blower will increase output, but it still draws in fresh air, which defeats the purpose of the button in the first place. WTF?
when driving through a dusty area/smelly area, closing the vent never seems to work. i still think it's a defect.
Moderator Alumnus
Mine acts the same way...when i took off the dash to do my video-navi mod I looked at it and everything looked ok, but it just didn't close all the way and nothing i could do would have fixed it. I think it was a design flaw or there might be more reasoning behind it (might need fresh-air so people don't die from carbon monoxide, etc..)
to pull codes from the HVAC hold down auto/off buttons while putting the car in ACC mode. keep holding, if you see any weird lines (half characters), youll have to look it up in the service manual
It's a safety precaution. Even if you turn your system completely off you should still feel outside air coming in from the floor vents. It's to prevent CO poisoning as previously mentioned.
Can someone confirm if you get any led blinking digit by going into diagnostic mode?
SidhuSaaB
05-30-2020 12:40 AM
navtool.com
31
11-16-2015 08:30 PM
joflewbyu2
10-08-2015 11:16 AM
navtool.com
09-25-2015 05:15 PM
