AHHH, my first scratch!
Old 05-27-2002 | 01:46 PM
JD7's Avatar
JD7
Rizzie's the color!
Unhappy AHHH, my first scratch!
Well it finally happened i knew it would. Its not really a scratch but more of a scuff on the back bumper,its about 4in long. Anyone know any products that can help?
Old 05-27-2002 | 01:57 PM
samkws's Avatar
Comptech Freak
try the melguair's scractch remover...
i have soem very minor scractes on both door side
probably some rocks hit it when i was on hwy....
Old 05-27-2002 | 07:02 PM
2007AcuraRL's Avatar
try 3M Swirl and Scratch remover. Its in a smallish black bottle. It is designed to remove 1500grit or finer scratches. if the area around the scratch is slightly raised (ie. you can feel the edge with a fingertip), which it probably is if its into the eurothane bumper, you might first try leveling/smoothing it out with 1000 grit and then 1500 grit wet sanding papers. Dont rub too hard and you wont risk taking off the paint around the scuff. Then use the 3M stuff. This is the preferred method to using rubbing compound, which i have never found to work at all.
Old 05-28-2002 | 12:11 AM
JD7's Avatar
JD7
Rizzie's the color!
thanks for the info guys, ill let you know how it goes
jsonkimz
03-28-2016 07:49 PM
datadr
03-23-2016 01:39 PM
InFaMouSLink
10-30-2015 09:43 AM
SinCityTLX
55
10-11-2015 01:20 AM
Hines57
09-24-2015 01:58 PM
Quick Reply: AHHH, my first scratch!
