Aftermarket headlights or OEM
Chapter Leader (Southeast Region)
I have been looking at getting another set of OEM headlights and they around 300$ brand new. Reason being is mine keep turning yellow every year even though i clean them and polish them once a month. My question is, is there a big difference between oem and aftermarket headlights that say like oem? I dont mind spending the double on the headlights as long as it is worth it.
Stephen00TL (02-02-2013)
The following 2 users liked this post by hamburglar490:
Stephen00TL (02-02-2013),
victus1 (02-02-2013)
They all seem to get a hazy clouded appearance through time being exposed to the elements. Cleaning and buffing, along with a quality sealant seems to be a temporary fix. I've often wondered about trying an ultra fine sanding of the lenses, followed up by an epoxy based clear-cote.
My original headlights lasted about 10 years before they started getting bad. However for the past few years I have to get them cleaned again to make them look good. I'm tired of spending money every year to get them cleaned so I'm buying a new set and figured I'll be good for a few years. Plus I'm going to do what tony03 suggested and use the clear film
Main reason is I don't want to mess up a brand new set of headlights. Also right now with work and school I don't have much time. I don't mind spending the mony for somebody to do it that knows what he is doing.
2003 TL-p
Iv used Mother's Plastic Polish with great results. I applied it a few times and have gone years without yellowing, even with the road salt around here. Sunlight is the most damaging to any exterior plastic. Give Mother's Plastic Polish a try, just rub on a generous amount, let it dry to haze and buff off.
It appears as though you'll have a spare set of headlights for somebody to experiment with !
Yeah, sometimes certain things are better left to an experienced pro......especially when you
have limited time and are unsure of the finished project !
Get one of the polishing kits. The polish comes with a uv protectant in it to help keep it from yellowing. Plus for 20 bucks and 30 min of your time its much cheaper
I've found this link concerning sealing. Have yet to try it myself but it sounds like it's worth a try
http://www.autogeekonline.net/forum/...lant-idea.html
http://www.autogeekonline.net/forum/...oat-2-0-a.html
trinikidcl
09-04-2015 12:56 AM
dlknight
09-02-2015 10:42 AM
