Aftermarket Bluetooth
I want to install in my TL hardwired Bluetooth. You know, one of these available on the market; Parrot, Sony, Motorola. Have anybody done that? How hard it is to connect it to audio system, especially with NAVI? Any advice is appreciated.
Originally Posted by JetBlackAC
i know a friend of mine tried to do that in his 01 tl, but didnt work
Do you know what was the problem? As I started to investigate, I found (was told) that to mute stereo I have to hook-up Bluetooth to Bose system. Apparently, this is not possible (?) due to the fact that in Bose every speaker has own amplifier (?). Any information on that from your friend?
Originally Posted by Nyses
what can you do with bluetooth in the car? use your phone with it?
The penguins are crazy
yes it is possible, just dont do it yourself. expect about $150-200 in labor at least, plus any extra if they have to connect through factory amps, especially if the amps are in the back of the car. the parrot is a great piece, pairs with up to 3 phones if memory is correct...
Former Sponsor
Originally Posted by mlionel
Thanks for reply.
I would recommend either the Motorola or Nokia Bluetooth kits. Both are very simple and work very well. Also pretty easy to install. You could probably do it yourself.
If you would like to install the kit yourself, let me know. I can give you the wire colors.
Bluetooth Kit install question
I was ready the forum and you mentioned that you know color codes for the wires to connect Bluettooth Handsfree Kit. I have purchased a HF1000 and will try to hoop it up to 2003 TL-S. How hard is it to remove the radio and is there a mute lead on this radio.
I had HF1000 installed in my TL by pro. Because we have Bose system that has every speaker with amplifier, you cannot mute stereo. What was done in my car was that as phone call come, or I wold place a call, it would shot the stereo completely, and it would restart itself 3-5 seconds later after phone call is finished.
Originally Posted by uncald4
The Parrot is a great product. But a bit expensive and not so installer friendly. I would not recommend it unless you really must have it. The Parrot uses a very "pish-posh" relay system to mute and pipe it's low voltage signal into your amplifier. The TL's amplifier is inside the deck.
Here is a TL solution for the Parrot bluetooth handsfree kits that mutes the stereo and is plug and play - see the QCHBB-HA interface here: www.parrotkits.com
Registered Charity
I priced having a stereo/phone installer install a blue tooth kit that would function properly and they wanted $450 to do it. I went out and bought a $50 visor speaker from Motorola instead. It works very well, clips to the visor. You touch a button to place a call. I just turn down the stereo from the steering wheel or turn it off when I'm using the cell phone. I realize you want something to integrate with the existing stereo, so my response isn't an answer to that, but it's another option.
MetalGearTypeS
08-29-2016 08:28 PM
SUPRMN84
10-07-2015 09:46 PM
