AEM air intake question
I am thinking of buying a AEM cold air intake. I heard it was very good for our cars. Can somebody tell me what the optional air by-pass valve is for and is it easy to install the whole thing yourself?
you is a noob...do a search but long story short...the bypass valve is a secondary filter mid-pipe...when the main filter gets water clogged intake air comes from the bypass valve effectively preventing water from getting into your motor.
jimster716:
"the bypass valve is a secondary filter mid-pipe...when the main filter gets water clogged intake air comes from the bypass valve effectively preventing water from getting into your motor."
Ha ha you tell him to go look then tell him something totally wrong The bypass valve is in no way a filter...it's just a valve. A valve that opens when water gets sucked up the intake pipe and creates negative pressure.
Oh and by the way, I really suggest you get it...it's like $30 most places...$40 from Tim, is easy to install, looks good, and gives you peace of mind...
Austin519
Austin519
Austin519
"Oh and by the way, I really suggest you get it...it's like $30 most places...$40 from Tim, is easy to install, looks good, and gives you peace of mind... "
hahaha sounds like you don't want to support Tim.... j/k
Originally posted by Austin519
jimster716:
Austin519
jimster716:
Austin519
jimster716:
Although it's really not a big deal...I was told by AEM that the added foam surround was a mechanical issue. Previously, they didn't have the foam surround, and there was a problem with the bypass valve opening prematurely. I was told by an AEM guy that the second gen of the bypass valve included that for that reason.
Austin519
Austin519
if i remember correctly, the first gen also had the foam surround...it was the rubber gasket that the foam attached to that was the cause of the suck-in and the subsequent failure of the bypass valve.
jimster716:
Well then maybe the AEM guy had no clue whatsoever as to what he was talking about
Austin519
jimster716:
Austin519
click here
i can also call my college buddy who works there if you want
the foam is the only filter element in the bypass valve...the bypass itself was not the foam but the whole point of the bypass valve was a secondary source of air when water clogs teh main filter...it can't just suck in air from the engine bay without filtration
jimster716:
Thanks The whole point in my other post was that the AEM guy I talked to must not have known what he was talking about...aka you're right. But thanks for the extra info anyway....
Austin519
Austin519
