acura TL 2000 heat issue
I want to ask. I just noticed that the engine temp. is always normal below the middle, except while I am parking It just goes to the middle and may exceed the little. I think there is no leak and the fan is working.
miles? timing belt water pump maintenance? coolant age?
you're not giving us much to work off of...
Location would probably help as well. Idling in traffic in a Houston, TX summer it may not be out of the ordinary.
Also, are both fans working? Mine started running hot when one of the fans was going out.
