Acura Car Cover
Acura Car Cover
I am thinking of getting this for my car. Any thoughts or comments on this? Should I get the Acura one? or is there another brand that is better??
Thanks!
Thanks!
I got the Noah cover from www.calcarcover.com . Cheaper ($159.99) and very good quality. Plus.. it fits perfect to the car!!
1 Post
The ACURA car cover is made by COVERCRAFT for ACURA & HONDA with company name for each model car. The one I got from ACURA when I got the car is best for most situation.
For example the NOAH one from CoverCraft is a High- tech barrier fabric that provides water & dust resistance. It also has better dig protection & heat protection. The one I have is also CoverCraft but it is called weathershield & is the ultimate in all weather protection better than the NOAH one. But the NOAH has better heat insulation & better ding protection. The weathershield on the other hand is lighter wieght & has easier storage with the smallest storage space of them all. The NOAH cover has better ease of handling in the wind. This is taken it off the car when its real windy outside because its heavier than the weathershield. But the weathershield is lighter & softer to the touch to your paint. The NOAH cover cleaning/care requires that you clean it in a larger laundrymat type Commercial Washer & let it Air dry. The weathershield can be cleaned in your HOME washer & dryer. But you can clean them each on the car with hose & let them air dry on the car if the weather is good.
wusty23jd
09-24-2015 11:41 AM
