Acura 3.2 TL Headlight switch replacement
I broke the headlight switch so now only my daytime running lamps are on. I disconnected the battery. I remove the upper and lower steering wheel covers, unscrewed the 2 screws for the headlight switch but the thing won't move. Is there another screw or some lever that I am missing to get the headlight switch out.
Attached is the photo the thing is stuck....or I am missing something.
If the steering wheel covers were removed....and the two retaining screws were taken out for the switch assembly, then the only thing that would be left holding ....is to disconnect the switch's wiring harness ? Then just pull it out.
mada51589
05-03-2022 08:54 PM
Mike Bertram
09-10-2015 09:27 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
