Abs tcs help
Abs tcs help
hey guys I just picked up a 2000 tl and im still trying to figure out these abs and tcs codes...anyone know what the problem is and where do I start on fixing these codes???
abs codes: 52 and 61
tcs codes: 24 31 and 61
thanks in advance for all your help
well i ran into sort of same problem last year. i know TCS code 31 is "traction control inhibition" meaning something with the ABS system causing TCS to turn off and light stay on. usually this is caused with faulty wheel speed sensors. but a faulty WSS will usually throw a 17 or 18 19 code somewhere around that range i think
check any ABS related fuses and relays. if ABS codes are the same throughout acura, according to team integra.net ABS 52 = motor stuck off and 62 = ignition voltage
Jamus22
06-11-2023 10:08 AM
mada51589
05-03-2022 08:54 PM
