"99 TL EGR valve recall
Old 12-17-2003, 08:26 PM
9th Gear
dandk33's Avatar
Wink '99 TL EGR valve recall
Just had my EGR valve replaced under a new recall. Thank You Honda Motors of America!!! ( 8yr/80,000)
Old 12-17-2003, 08:29 PM
Was this a nationwide recall?
Old 12-17-2003, 08:44 PM
9th Gear
dandk33's Avatar
Wink
8yr/80,000ml ext. Check engine light must be on and OBDII must
indicate EGR problem. Otherwise, the stealer was going to charge
me $120.00 to check it out. There was a problem with the EGR
vavle clogging on certain models. I think that the CL's have this
recall as well.
Old 12-17-2003, 08:52 PM
6th Gear
is the EGR valve the same thing as the ignition intake valve?
Old 12-17-2003, 09:07 PM
9th Gear
dandk33's Avatar
EGR stands for "Exhaust Gas Recirculator". They have a kit for
this recall.
Old 12-20-2003, 05:28 PM
04AcuraTL6speed's Avatar
The 6 gen Accord had this problem too. Symptom is check light on, and your car will have shut off on warm/hot starts. The EGR will clog up with carbon deposit and it will have insufficient flow. If your out of warranty, they sell the recall kit ~$80...but you have to take ur throttle body off and ur intake manafold off to replace it. Honda/Acura will charge you 1.5 hr of labor to do it when ur warranty is out. I don't know how much they charge per hour.
Mike734
12-10-2021 01:25 PM
fifer16
1G RL (1996-2004)
10-05-2015 10:12 AM
thegipper
09-28-2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
09-28-2015 12:33 PM
prbori
09-27-2015 01:37 AM
Quick Reply: "99 TL EGR valve recall
