99 tl. comptech icebox... too loud!?
i installed the icebox today on my 99 TL and once we got all done.. i think it is pretty loud!
i dont know if its installed wrong or not.. but if any of u guys have a 99 tl with the icebox let me know how ur intake sounds!
from what i heard it should be pretty quiet but WOT is crazy loud..
i never had an intake on my car so sorry for this n00b question.
I just put a CAI on my 99TL and it sounds like ASS when your in D4 and kick it to the floor. VERY Ghetto imo ! But it does sould sweet when you are in SS mode and back off the throttle between shifts.
Originally Posted by Mongolian
Icebox should sound pretty close to stock. It's a bit louder during WOT. Maybe you installed it wrong??
i hate thoose useless coolant lines! :argh:
Originally Posted by chuckz
how could it be installed wrong? im the one who helped install it on the car and i don't see how anything could be wrong. the thing that gave us the hardest time was the bracket that u bolt to the box and the frame. when we did that the box sat too high and the hood couldn't close, so we took it out and theres nothing holding the box to the body. any input on this?
it is no lie that when you put on an aftermarket intake on these 3.2VTEC engines that they scream like a V8 when you punch it hard - the Icebox lets out slightly less noise than a "real" CAI, but not much less at all. So just get used to it if you want to keep the intake
everything seems fine..
all the hoses are connected right..
the snorkle looking thing is still connected..
the install felt a little tight and im not sure if the box is sitting in the right spot.. seems a little further away from the light maybe thats the problem?
i didnt read about anyone doing that?
I found out about having to do this from other posts here on AZ. I think it applies only to '99s.
thats why i have more exterior mods then engine lmao
ok i fixed the problem
now i have a humming noise at idle.. is that normal or is there something else i need to do?
Originally Posted by MikePA
Humming noise at idle is not normal. Where's it coming from?
i guess the WOT sound is normal.. sounds crazy but i know there is nothing wrong with the install.. i just have this annoying HUMMING sound
i dremelled the hole bigger for the half moon so it fits by the light and secured the box down with the screws..
the hum has nothing to do with the icebox (if its the same noise I am talking about). You can take off the icebox and have nothing on the throttle body, and you will still hear that hum...just comes from inside the engine, and with the stock setup, the resonators cancel that noise - because I had that noise when I had the stock airbox on after I took out that small second intake resonator
