97 TL trans in a 99 TL
Old Jan 24, 2018 | 08:29 AM
kseriesonly's Avatar
9th Gear
Will a 97 TL Auto transmission fit in and work in a 99 TL.. Need help asap
Old Jan 24, 2018 | 09:04 AM
bro it's only been 30 minutes..
The 2nd gen TL is 99-03
97 is a first gen TL.. probably will not work, I'd look into an Accord v6 (06-07) as a trans replacement
https://acurazine.com/forums/second-...n-swap-905115/
Old Jan 24, 2018 | 09:09 AM
9th Gear
I know that some of the 97 came with a 3.2 liter and 4 speed trans same as the 99.. I found one from a 97 thats why I'm wondering if it will work.. Also is the accord trans a straight forward swap or is there anything else needed to do the swap.. all help is greatly appreciated
Old Jan 24, 2018 | 09:11 AM
9th Gear
never mind, I read the link you shared.. I'm not trying to swap all the harness's and ecu.. I'm looking for some thing that is straight swap old out with new
Old Jan 24, 2018 | 09:13 AM
Ahh... you have a 99, that won't apply.
Looks like you need to look for another 99 TL tranny .
horseshoez's Avatar
Latent car nut
If I am not mistaken, the 4-Speed auto from the Gen 6 V6 Accords should work.
Old Jan 24, 2018 | 09:18 AM
9th Gear
Would that be the 97-02 Accord? Has anyone done that swap?? im guessing that a 97 TL trans wont work
Old Jan 24, 2018 | 09:28 AM
horseshoez's Avatar
Latent car nut
Not sure if anyone has even tried the 97 to 99 swap, but I'm pretty sure I've seen reports from folks who've done the swap from the Gen 6 V6 Accords. That said, something in the back of my brain is saying there was an update to the 4-Speed automatic done in 1999, so it might be only the 1999-2002 transmissions will work. If you call a bone yard they have an interchange manual and should be able to confirm if the Accord tranny will work.
Old Jan 24, 2018 | 09:39 AM
9th Gear
ok I will check into it. Do you know if the harness and ECU need to be changed
Old Jan 24, 2018 | 09:40 AM
You know what won't need a harness or ECU swap?
a 99 TL transmission
You seem to want to find the easiest possible solution so why not just look for a 99 TL transmission?
Old Jan 24, 2018 | 09:44 AM
9th Gear
I've called about 10 junkyards near me and noone has a 99.. only one had a 97 prompting this post
Old Jan 24, 2018 | 09:52 AM
Flipster23's Avatar
Why buy another 99 transmission when they're shit.
Seriously, 6 spd swap. Yea, it's not a direct swap but it seems like you will be having someone else doing the work anyways?
Old Jan 24, 2018 | 10:09 AM
9th Gear
But does anyone know if the 98-99 accord trans will work in the 99 TL
Old Jan 24, 2018 | 10:11 AM
those are just as shitty..
i have a 99 accord sitting at home with a shit transmission. about to part it all out and scrap the shell
Old Jan 24, 2018 | 10:12 AM
Flipster23's Avatar
99 Accord tranny is shitty.
Old Jan 24, 2018 | 10:38 AM
9th Gear
From what I have been told by several junk yards the 99 will only work with a 99
Old Jan 24, 2018 | 10:39 AM
Old Jan 24, 2018 | 10:40 AM
Flipster23's Avatar
Rebuild or swap 6 speed.
I'm guessing your tranny took the shit?
Old Jan 24, 2018 | 12:11 PM
9th Gear
Yea it did.. what typically needs to be rebuilt in the 4 speed trans.. Is it the clutch packs?
Old Jan 28, 2018 | 08:18 PM
Darksyne's Avatar
Honestly if you're having a hard time tracking a 99 TL transmission, then your best bet is to cut your losses and sell or scrap the TL for either another cheap 2nd gen with a working tranny (just change the fluid every year and your good) or accord or Camry if you want reliable transportation. Or upgrade to a clean 3rd gen TL if you have the money to spend.
Rebuilding or replacing that 4speed trans is too costly considering the age of the vehicle and the rarity of the 4speed, I'd rather spend that kind of money to upgrade to a newer used car, good luck.
Old Feb 3, 2018 | 02:27 PM
tripleguy's Avatar
What kind of mileage do you have on your 99? Most of the failures I've seen have been in the upper 100s to lower 200,000 miles. If the car has low miles and is in otherwise good shape, you could have it rebuilt but it ain't going to be cheap.
gavriil
Dec 20, 2024 12:09 PM
barnett468
Mar 21, 2017 09:28 PM
hpcacura
Dec 17, 2016 10:02 AM
Brad.weber1990
Dec 9, 2016 01:39 AM
Aleax
Oct 29, 2016 03:39 PM
