90K service maintenance question??????
What kind of serivce should i get service at 90K ?? Any suggestion would be very appreciated.
Timing Belt?
Water pump?
Tune up?
Radiator flush?
transimission flush?
any thing else?
Timing Belt?
Water pump?
Tune up?
Radiator flush?
any thing else?
Sippy Cup (x2)
Here is what is on the owner link website.
Replace engine oil.
Rotate tires (follow pattern on page 264 of your owner's manual.
Replace engine oil filter.
Inspect front and rear brakes.
Check parking brake adjustment.
Inspect tie rod ends, steering gear box and boots.
Inspect suspension components.
Inspect driveshaft boots.
Inspect brake hoses and lines (including ABS).
Check all fluid levels, condition of fluids, and check for leaks.
Inspect cooling system hoses and connections.
#Inspect exhaust system.
#Inspect fuel lines and connections.
# = See information on maintenance and emissions warranty, last column, page 223 of your owner's manual.
Replace air cleaner element.
Inspect and adjust drive belts.
Replace dust and pollen filter.
You should probably also register here.
Replace engine oil.
