90,000 Mile Tune-Up
Type II Coupe
90,000 Mile Tune-Up
What exactly do they do??? I got quoted 500.00 for the sevice from my ACURA dealer today... Kinda wondering if I can do it all at home... Wondering if I would be able to clean the Fuel Injectors though... Anyone have answers??? Thanks in advance!
This is what Acura should be doing at 90,000 miles.
Recommended at: 30,000; 90,000 Miles
Engine Chassis
Engine oil & filter - change
Air filter - replace
Engine operation - check with scope
Cooling system - inspect & replace engine coolant
V-belts - adjust
Service fuel injection system - check
Exhaust system - inspect components and check emissions
Inspect belts/hoses
Tires - rotate & set tire pressure
Undercarriage - check for damage and condition of rubber boots
Power steering system - check & add fluid
Transmission Brake System
Automatic - replace fluid
Manual - replace fluid
Differential - replace fluid
Components (pads, lines, hoses & calipers) - check condition
Brake fluid - replace
Hand brake - check & adjust
Electrical Miscellaneous
Battery - check
Electrical equipment & lights - check operation
Diagnostic system - check operation
Lubricate chassis, hinges & trunk
Wiper blades - inspect & clean
Test drive car
Wash & vacuum
For peace of mind, I'd probably do it.
Engine Chassis
V-belts - adjust
Inspect belts/hoses
Battery - check
Test drive car
Wash & vacuum
mada51589
05-03-2022 08:54 PM
Legend2TL
11-20-2015 07:31 PM
mugen_kid
11-13-2015 10:38 PM
