6000k
BlingBling INSPIRE 32V
Of course you can get 6000K bulbs on 00TL. You can get D2R for our TL. It's direct swap. Some of members got D2S bulbs which are for projector type HID's. It does require little bit of modification on the bulbs though. Good Luck!!
1998 TL --> 2003 TL uses the same type of bulb (D2R), so if it fits for others, must fit for your 2000 TL. D2S takes about 5 seconds of your life with a dremel tool to modify...probably 30 secs with nail filler.
Originally posted by JangoFett
So what's the difference between D2R and D2S? Is one of them suppose to be brighter than the other??
Originally posted by EmuMessenger
Oh boy. Here we go again.
I wish I had the courage to perform the 6000k install.
Good luck with them!
Originally posted by UCLAtl
How hard is the install? What do you gotta do?
UCLAtl
UCLAtl
For the right side, the windshield fluid tube is blocking your way. You can remove the top section of the tube to give you more room. Then follow the steps above to swap the right side bulb.
The clips and bulbs are unidirectional, meaning they look the same for both the left and right sides. So you don't have to worry about remembering which clip was from which side.
tommiesay
12-12-2006 12:39 AM
