60,000 Mile Service comming up...
Sig Rho's Finest
so my service is comming up. does anybody have a comprehensive list of what this includes? all the parts and services? thanks
Now watch this drive
From AcuraCare:
60,000 mi/96,000 km/4 yrs Scheduled Maintenance
Replace engine oil.
Rotate tires (follow pattern on page 264 of your owner's manual.
Replace engine oil filter.
Inspect front and rear brakes.
Check parking brake adjustment.
Inspect tie rod ends, steering gear box and boots.
Inspect suspension components.
Inspect driveshaft boots.
Inspect brake hoses and lines (including ABS).
Check all fluid levels, condition of fluids, and check for leaks.
Inspect cooling system hoses and connections.
#Inspect exhaust system.
#Inspect fuel lines and connections.
# = See information on maintenance and emissions warranty, last column, page 223 of your owner's manual.
Replace air cleaner element.
Inspect and adjust drive belts.
Replace dust and pollen filter.
Replace engine oil.
its a waste of $$$$$ just keep doing the standard maintanence (oil/filter/tranny fluid/air filter) thats all you need to do till 100k then get the belts/timing belt replaced and water pump (which i need to do yet)
Zonian22
11-14-2015 01:20 PM
nanos
11-12-2015 08:41 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
