6 speed conversion rewiring help
Old 09-19-2017, 11:49 PM
8th Gear
hmongcuzzo's Avatar
I converted my 2g Type S from auto to manual, bought it with a bad auto transmission. I'm using the auto harness, auto ecu, everything on my car is original auto except for the transmission. I am already done with the swap. What I am stuck on is that I can only get the engine to run if I jump the starter by sending a positive direct from the battery to the starter. When I turn my key in the ignition nothing happens. Anybody have experience with this. And also does anybody have the ecu harness diagram. Just need to know which plug is A,B, and C. I will run in limp mode until I can order an aftermarket ecm just need help so I don't have to continue jumping the starter by hand.
Old 09-19-2017, 11:56 PM
Unregistered Member
Karanx7's Avatar
Your car no longer understands that it's in "park." You would have to rewire a bunch of stuff just to get it to start in limp mode. Not really worth it, because you'd have to undo that stuff when you get an AEM EMS 2. Just buy the EMS. Your Auto ECU won't run the manual tranny.
Old 09-20-2017, 12:21 AM
Skirmich's Avatar
Received 1,017 Likes on 867 Posts
Not worth the trouble to rewire anything.
