5W or 10W syn. oil. Which one is better?
What Lord Stanely said is correct. Also 5w-30 has a more wide temperature range of operation and is thinner. Many will claim that you will get better gas mileage using 5W-30. I believe it, but don't have proof on it, but from my experience, I think I get better mileage on 5W-30, but then again, it could be more freeway driving at that time, who knows...
10W-30 is not as versatile as 5W30, but since CA weather is not THAT extreme either way (compared to Maine or Chicago for example) 10-30 is can be used. Some mechanics will claim that the older your car gets, it's better to use the thicker oil (1030) because it won't slip through the cracks as much. I don't know if it's true. Regardless, since you're in CA, i don't think it matters that much, just change it every 3000 and stick to the manual if you ever have doubts, so go with 5-30 if you can, and with 1030 if it's on sale.
If you're change your own oil, buy 5 -30.
Oracle Apps/Database Dude
where you are I would stick with 5-30
I use 10-30 in the winter, it is a little thicker. I use 5-30 in the spring, summer and fall. This implies I change my oil 4x a year.
Bottom line keep 10W away from our cars and definitely dont use it in the winter
