500 degree paint for headlights
NBP and lovin it
I bought 500 degree resistant black gloss paint b/c im blackenin out my headlights tomorrow while i clear them. I was wondering if this paint was good enough to withstand the heat in the headlights. People have said you need 1200 and others have said the headlight does not get hot at all. So do i need to step up to 1200 or is 500 good enough.
you DONT need high temp paint!!! the lights dont get that hot! regular automotive paint would suffice.
Originally Posted by Mr Hyde
500 is overkill itself as everyone said.
Also, if use on headlights, you "must" cure the paint, otherwise you are facing "potential" problems from the fumes fogging up the headlights, because of the heat generated from the bulb and time.
NBP and lovin it
dont i just, shake the can etc like the directions say, paint the chrome piece then apply clearcoat, allow 2 hours to dry and put it back in the headlight and seal it up?
Originally Posted by darkfox12
what do you mean by cure'in the paint?
i paint cars and have painted many engine parts(including the block and heads) with automotive paint. it can withstand alot of temp. headlights dont produce that much heat. if they did the Plastic headlights would melt
and as for clear does the can say the paint requires clear coat? or is it a single stage. ive never seen a high temp paint that required clear
ic, so should i not even use the 500 degree black paint or is that fine for blacken the headlights out
good luck!
Originally Posted by fsttyms1
its a term for drying.
so you basiclly mean sand down the chrome piece a bit
i
yes sand down the areas that your going to paint with any thing between 220 and 400 grit. then paint away. many light coats are better than heavy ones
i think he means the chrome piece in the headlight casing. If u sanded that down with 220 grit ud ruin it cuz its already smooth wouldnt u?
i
aiite, thanks fsttyms. Ill post pics once im done tonight, hopefully everything goes well.
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
AmplifiedDetails
09-24-2015 02:55 PM
