45k
Old 05-21-2003 | 12:52 PM
nick79's Avatar
45k
i will get to 45,000 miles on my 3.2TLS and i was wondering wut kinda service is good to do. i really havnt serviced it much except for tranny and oil changes and my shocks are brand new and rotors are resurfaced.
Old 05-21-2003 | 04:07 PM
mushutofu's Avatar
not much left. I think at 60K you want to do some other things like sparks/wires
Old 05-21-2003 | 05:03 PM
nick79's Avatar
i thought the sparks and wires are good till 110,000 miles.
also wut about the brake flush, when should i get it.
Old 05-22-2003 | 07:03 AM
clc's Avatar
clc
Don't forget the timing belt at 60k miles....
Why does my old sentra have a timing chain, and Acura uses belts?
Old 05-22-2003 | 09:26 PM
mp3coupe's Avatar
Nick79, When your due for your next oil change, change the trans fluid also. I would also clean or replace your aftermarket air filter at this time. I balanced the front tires on sat, and your best tires are on the front. That pretty much covers everything. You might want to pick up some wiper inserts also.
CLC, the T-belt is good for 105k
Toyota/lexus recommends t-belt at 60k
subaru is at 105
Nissan uses chains
Honda is starting to move over to chains, It will be a few yrs before they all have them. This was in the works in 1999....
coupe
Old 05-25-2003 | 02:30 AM
clc,
There is a constant debate over the use of a timing belt vs. a timing chain.
The engine runs MUCH quieter with a rubber timing belt, but has to be replaced (typically at 60k miles) at least our TLS says you can go over 100K
The timing chain will last the life of the engine but creates an obvious raspy sound. Just compare the Nissan engines to Toyota or Acura.
I like our quieter engines but I do find the timing belt change a real pain in the a$$! Plus, if you neglect to have it changed, you get real paranoid when taking road trips on an old belt... but then again, I'm paranoid about the tranny on long road runs as it is...
kmawani
02-08-2023 05:09 AM
mlody
12-04-2019 02:11 PM
xsilverhawkx
10-05-2015 11:00 AM
Quick Reply: 45k
