3rd and 4th gear pressure switches
I have a 2002acura TLS and my tranny has a hard drop into reverse and a prolonged switch from 3rd to 4th gear. The RPM will rise up and then it will switch into 4th gear a little hard. Now I've already done a 3quart spill ànd fill and put Lucas stop slip in and it helped quite a bit but I can still notice a struggle to get out of 3rd gear around 40 mph. My car only has 89000 miles on it and everything else works great on it. I'm wondering if swapping out these switches will fully fix the problem or if it's a waste of my money.!?! If anybody with more knowledge than me could help me out I would greatly appreciate it thank you...
Check your shift cable for wear, adjust if necessary.
You might want to try replacing the following.
1. ATF external filter.
2. Shift Solenoid C.
3. 4th clutch pressure switch.
4. Pressure Control Solenoids A/B & C. Check and clean the screens under these solenoids.
I'll try that this weekend I was already planning to clean the solenoids but I didn't know about the throttle cable thanks for the tip.
Solenoid Adjustment Tool - 88950-T - Sonnax
Looks like a pretty neat tool. Are there any resources on the web as to how we can adjust the solenoids properly? I'm really interested.
