2003 Windshield Wipers
My 2003 TLS is 4 months old and the winshield wipers are constantly clattering/skipping motion on the window. Is this a known issue? If anyone has experienced this issue please advise me what your fix was. By the way .... I clean the blades on a regular basis and there is no buildup of any sort on them.
Thanks!
Thanks!
At one point, they were changing the blades/fluid lines on the 99-02's because the lines were corroding and causing this type of reaction. You may want to tell the dealer that (they should change the lines/blades for you then).
Good Luck
Good Luck
are you using honda wiper blades?
i've noticed that i get great results when i use the honda blades, but get bad results when i use discount or off brand items.
even the expensive bosch wipers chatter.
you could try to strip the window of all build up.
use full strength ammonia.
07-16-2017 08:33 AM
Pham Alvan
03-16-2016 10:17 AM
