2003 tl trans leak
2003 tl trans leak
hello need some help, my 2003 tl high mile but well maintained decided to spray all of the trans fluid out of the solenoid under the brown connector, i figured it was rotted out so i bought a nice used part from ebay and same result start the car fluid sprays out fast
the valves i tested with 12v power bot work old and new has anyone else had this happen?
lost where to check next
not the gasket right under connector on solenoid valve in front of fill plug car was good before this.
can you see exactly where the oil spray is coming from on the solenoid? pics would help
In addition, check out
from This Thread to see all the gaskets and o-rings that should be replaced. Rubber ones might be reusable, but that paper one needs to be replaced every time. Also, check to make sure the bolts are not stripped.
I don't see a video.
These might help.
