2003 acura tl the things need to be done
hai guys i just bought 2003 acura tl with 170000 clicks on it. i dont know what need to be check or changed at this time ? plz help me guys
make sure the timing belt-water pump was done at 160kms/105kmiles
spark plugs were due then too..and every 100-150kms repeat all the above
change ps and brake fluids
ck coolant
ck battery condition at parts store (free) and clean connections
cabin air filter ($20)
new wiper blades for winter and washer fluid full
do a search for acura care canada (guessing thats your location)
register online and on phone to ck all recalls are done and online registration you can get the owner manual free-it lists the service needs
but in reality -any good tech can look the car over and see what you need
or you can assume a used car needs all fluids and go thru it with a good flashlight and socket set..ck every bolt for tightness
ck everything!
front and passenger side motor mounts fail all the time--look for oil traces on front and rear motor mounts as their failure signal- they are fluid filled and vac boosted (most years)
ck coolant
ck everything!
NOT able to register in my acura
ck coolant
ck everything!
ck coolant
ck everything!
do you have a USA car taken to Canada? that would explain it
saberlove
03-11-2021 09:29 AM
