2002 TL has a slight Miss
Slight miss when car warms up after 10 minutes check and changed all coil packs and Spark plugs cleaned EGR valve and ports check for all vacuum leaks PCV valve is checked Miss gets worse as car warms up more any suggestions would be much appreciated
also there are no code showing
Lol well it sounds like you've checked pretty much everything that I would suggest. Since it gets worse while warming up I would check for a bad o2 sensor or cat, maybe even a crank sensor or a combo of all of them... Good luck man.
