2001 TL Neon Light Problem SRS Light
Old 11-10-2003, 08:44 PM
acuratl_2nr's Avatar
I recently purchased some neon lights that you plug in to the cigarette lighter. When I plugged them in, they worked fine. When I unplugged them, it deprogrammed all my radio stations and it tripped of my SRS warning light. I was just wondering if anyone has encountered this problem and what you did to fix it. Any kind of help would be greatly appreciated! thanx peace
Old 11-10-2003, 09:09 PM
l33t
Darkshear's Avatar
the cig lighter is linked to a few cute things in our electrical system. the radio, the other power port, a few other things. plug a 12 volt battery in to the lighter socket and you can turn your radio on
You prob just blew a fuse or maby the neon just overloaded the circuit. unplug the negative from the main battery for 3 minutes and reconnect ot reset the comptuer. Your SRS computer will reset as well, unless its fried... otherwise, all will return to normal. and dont do that again
Old 11-12-2003, 12:08 PM
is the Mighty Favog
Tom Blasing's Avatar
Back about 10-12 years ago when I used to sell car accrssories we used ot sell the neon lights. The biggest warning we had to give people was that they should NOT be installed on a car with ABS brakes. Don't remember why but back then it was definitely a problem.
I know it's not what your expieriencing but it may point in the right dirtection.
mada51589
05-03-2022 08:54 PM
Bahamanurse1
09-10-2015 10:05 PM
HeloDown
09-08-2015 06:51 PM
3.5RLv-tec?
1/2G MDX (2001-2013)
09-07-2015 11:00 PM
Quick Reply: 2001 TL Neon Light Problem SRS Light
